🎉Community Raffle - Win $25
Join and Win
Hexa meshing with solid map
User: "mabefa"
Altair Community Member
Updated by mabefa
Hi, I have a solid which I trimmed with the function solid edit to make it mappable in a way to mesh it with solid map. After I trimmed that I used the solid map but the elements in the inferfaces surfaces between the parts I created have no nodes in common. Is there a way to make them with common nodes avoiding to do an equivalence after creating the mesh?
1 - 3 of 31
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi mabefa
    Doing an equivalence is the best option or you can manually replace the nodes through 1D > Replace
    User: "mabefa"
    OP
    Updated by mabefa
    Ok, thank you so much for the help.
    User: "Simon Križnik"
    Updated by Simon Križnik
    @mabefa
    Use the Node Edit panel (Geometry>Edit>Nodes>Assosciate) to associate nodes to a point, line, or surface/solid face.
