Hi, I have a solid which I trimmed with the function solid edit to make it mappable in a way to mesh it with solid map. After I trimmed that I used the solid map but the elements in the inferfaces surfaces between the parts I created have no nodes in common. Is there a way to make them with common nodes avoiding to do an equivalence after creating the mesh?
