🎉Community Raffle - Win $25
Join and Win
Error 153
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi, i dont understand this problem. How can i solve it ?
WARNING: The amount of memory allocated for the run is 1593 MB, which is larger than the specified (or the default) RAM= 1000 MB. This run will use minimum core processing in the solver.
************************************************************************ A fatal error has occurred during computations:  ***
ERROR #  153 ***  Exactly zero pivoting encountered during Numerical Factorization;  the model may have rigid body mode.
Solver error no. =       -503
spc set id =          2
index =          1
Possible reasons are:  1) insufficiently constrained model,
2) having rigid body mechanisms within the model,  ...
*********************************************************************** Note that estimated disk requirement exceeded available space.
See WARNING 1970 in the output file. ************************************************************************
 ==== End of solver screen output ====
==== Job completed ====
<?xml version="1.0" encoding="UTF-8"?>post-21342-0-09904300-1384902861_thumb.p
1 - 1 of 11
    Altair Employee
    OP
    Hi,
    it looks like your model has not enough constraints or other mistakes, which results in a singular stiffness matrix.
    But all possibilities are written in your attached screenshot. Check your model...
    Regards,
    Mario
