Error .tcl cfd mesh
Hello,
I'm trying to create a Tcl script file to make a cfd mesh.
I'm newbie to this, so I've made a cfd mesh with Hypermesh, I've translated the command file to tcl commands and I ran .tcl file.
But I'm getting this error:
Error 0
0
0
while executing
'*feinputwithdata2 '#nastran/nastran' 'bl_mesh_out.nas' 1 0 -0.01 1 0 1 1 '
(file 'C:/Users/usuario/Documents/command_cfd_2.tcl' line 131)
invoked from within
'source {C:/Users/usuario/Documents/command_cfd_2.tcl}'
('uplevel' body line 1)
invoked from within
'uplevel #0 'source {$file}''
(procedure '::HM_Framework:/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_FileLoad' line 60)
invoked from within
'::HM_Framework:/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_FileLoad 24'
(menu invoke)
Import process Messages
Error: Could not open file bl_mesh_out_.nas
In fact, 'bl_mesh_out.nas' doesn't exist in my computer. How is this possible?I just took the command file created by Hypermesh.
Thanks in advance.
Hello,
do you have deleted the 'command.cmf' before you have started to record your command file?
Otherwise the line is from a previous session.
Since HM doesn't delete the command.cmf, you have to do this manually.
(so it is a good idea to do this generally from time to time)
Regards,
Mario
