Adhesive Connection between two Solids
Muhammed Koc
Muhammed Koc Altair Community Member
edited October 2020 in Community Q&A
Hello,
i try to simulate a adhesive connection between two solids.
First issue, i dont know how to create a adhesive connection, i tried to create it by Shell-elements (2D-->connectors-->area-->Type:adhesives), but i cant do it well.
Second issue, how to create the adhesive connection by Solid-elements.
Thank you for your respond.
Muhammed
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2020
    in HM Help (always look at it) you will find the documentation of this panel 'area' and a tutorial showing how to use connectors area.
    If you're using OptiStruct there is also Cohesive Elements, since version 2019.2, i think.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.65b225e63e37eb3ac19bdef582044671.png
  • Muhammed Koc
    edited August 2020
    Thank u for your respond. I use optistruct 2017.2
    I try to superimpose my 2D Mesh with the 3D Mesh to create two identic Meshs at my solids to connect them with a adhesive. I will continue.
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2020
    the connectors adhesive needs some gap to create the solid elements, otherwise they will be squized.
  • Muhammed Koc
    edited August 2020
    How can i create a adhesive Connection in a hole ? See picture. The Box of the prisma is a Solid. The Glasplate is also a solid.
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2020
    if you want to fill this large gap with adhsesive, then you should create a mesh for this hole and tie it to the rest of your model. I believe this would be the correct approahc.
  • Muhammed Koc
    edited August 2020
    3d Mesh and set properities as such as the adhesive contains ? How can i tie it ? Just with equivalence the nodes ? That destroy many elements. :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2020
    yes.
    depending on what you want, you could just create a TIE contact, bonding everything together. Otherwise, extract faces, close the open cap with shell mesh, and create the tetra mesh, with nodes connected.
  • Muhammed Koc
    edited August 2020
    Is it possible to meet us  on zoom session to show you my model ? :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Welcome!
Welcome!
