Adhesive Connection between two Solids
Hello,
i try to simulate a adhesive connection between two solids.
First issue, i dont know how to create a adhesive connection, i tried to create it by Shell-elements (2D-->connectors-->area-->Type:adhesives), but i cant do it well.
Second issue, how to create the adhesive connection by Solid-elements.
Thank you for your respond.
Muhammed
1 - 8 of
81
in HM Help (always look at it) you will find the documentation of this panel 'area' and a tutorial showing how to use connectors area.
If you're using OptiStruct there is also Cohesive Elements, since version 2019.2, i think.
