🎉Community Raffle - Win $25
Join and Win
Why the result show "Failed to attached result" in RADIOSS
User: "Sukwasa"
Altair Community Member
Updated by Sukwasa
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.5e671bb54a3556b888576ce42506f27b.pngI
I found this problem many times. I am not sure that happen because of the boundary conditions or anything else.
And I imported model Optistruct file in Radioss solver, Is it ok or not?
Thank you for helping!
1 - 7 of 71
    User: "sandeepballiwar"
    New Altair Community Member
    Updated by sandeepballiwar
    When you are loading the solver deck in hyperview, uncheck the load result.
    .rad is a solver input which doesn't contain any results that is the reason you are getting that error.
    User: "Sukwasa"
    OP
    Updated by Sukwasa
    Thank you for your reply.
    Now, I am understand .rad is not a result file but after running analysis that have only both of .rad files, follow this picture.
    That's mean the program doesn't run, right?
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Yes, the program doesn't  run ,
        did u run analysis ?
    User: "Sukwasa"
    OP
    Updated by Sukwasa
    Yes, I have run analysis already and I already use model checker, it doesn't has error anythings.
    Is there any other problem in the program that is possible? @Pooja S
    Best regards,
    User: "Simon Križnik"
    Updated by Simon Križnik
    @Sukwasa
    If the analysis ran without problems, the result should be available in the <modelname>.h3d file. We can also load the results WHILE simulation is running by opening <modelname>.A01 animation file.
    <modelname>_000.rad is a starter file (containing loads, BCs, material, properties, mesh) and <modelname>_001.rad is an engine file (containing simulation controls).
    Altair Employee
    Hi
    Download  the ebook from the below location and  try  the tutorial mentioned in the book or from Altair hyper works help for better understanding
    https://altairuniversity.com/free-ebooks-2/free-ebook-crash-analysis-with-radioss-a-study-guide/
    User: "Sukwasa"
    OP
    Updated by Sukwasa
    @Ivan @Pooja S Thank you very much for your reply!
