🎉Community Raffle - Win $25
Join and Win
Calculate the sum of a series
User: "Dung the most handsome man"
Altair Community Member
Updated by Dung the most handsome man
Hi everyone,
the picture below is the sum of a series that have infinity limit, and i don't know the suitable function to deal with the problem.
Thanks for your help.
1 - 3 of 31
    User: "L Moretti"
    New Altair Community Member
    Updated by L Moretti
    Hi Dung,
    you can try this:
    clc, clear
    Sum = 0;
    for k=1:100000
        Sum = 1/k^2 + Sum;
    end
    OP
    Thank you, but i need the more accuracy result, cause exactly, the result is pi^2/6. I tried your solution before, the result is an irrational number.
    Anyway, thanks for your suggest.
    User: "manoj kandukuri"
    Altair Employee
    Updated by manoj kandukuri
    Hi Dung,
    you can get more accurate result by having a tolerance condition inside a while loop. something like below:
    clc, clear
    sum = 0;
    sum_before = realmax;
    tol = 1e-12;  % tolerance value
    i = 0;
    while (abs(sum_before - sum) >= tol)
        i= i+ 1;
        sum_before = sum;
        sum = sum + 1/(i^2);
    end
    Hope this helps
    Thanks,
    Manoj kandukuri
