Hi everyone,
the picture below is the sum of a series that have infinity limit, and i don't know the suitable function to deal with the problem.
Thanks for your help.
Hi Dung,
you can try this:
clc, clear Sum = 0; for k=1:100000 Sum = 1/k^2 + Sum; end
Thank you, but i need the more accuracy result, cause exactly, the result is pi^2/6. I tried your solution before, the result is an irrational number. Anyway, thanks for your suggest.
you can get more accurate result by having a tolerance condition inside a while loop. something like below:
clc, clear sum = 0; sum_before = realmax; tol = 1e-12; % tolerance value i = 0;
while (abs(sum_before - sum) >= tol) i= i+ 1; sum_before = sum; sum = sum + 1/(i^2); end
Hope this helps
Thanks,
Manoj kandukuri
