Altair RISE
Nominate Yourself Now!
How to do a parameter sweep
User: "Fabio Borrelli"
Altair Community Member
Updated by Fabio Borrelli
Hi there,
I have some problem to do a parameter sweep operation with a simple rectangular patch. I click on application macro, model construction and then parameter sweep. I choose the parameter that I want to vary and the number of samples, but when I click next it doesn't ask me where I want to save the parameter sweep and it doesn't generate any xml file that I can use on postfeko to see the graphic variation.
Anyone knows how to solve this problem?
My Feko's version is the student edition 2021.0.3.
Thanks.
1 - 8 of 81
    User: "Jaehoon"
    Altair Employee
    Updated by Jaehoon
    Please check that the new directory "parameter_sweep" is generated under the current directory. (The .xml file and the other feko files are saved there. )
    Thank you.
    OP
    Hi, thank you for the answer, I appreciate it.
    The problem is that the "parameter sweep" directory is never generated.
    In one of the two images which I have attached there are the files that Feko generate when I run a parameter sweep, and that is the original directory where I saved the file "check" (which contain the patch that I've mentioned before).
    User: "Jaehoon"
    Altair Employee
    Updated by Jaehoon
    Hi,
    Did you see the following window after clicking on "next" in "Parameter sweep - define variable ranges"?
    (This is the normal procedure.)
    If not, please install again Feko (maybe 2021.1).
    Thank you.
    OP
    Unfortunately, Feko doesn't show me that window.
    Furthermore, I tried to install again Feko (only 2021.0.3 because it's the only version that I can find in the email in response to the request) and even after a recovery of Windows.
    It is quite important for me to be able to use the parameter sweep since I am doing a study on a QHA and I need to find the best configuration of the parameters and to use them in postfeko in order to analyse them.
    Is it possibile to use another version, maybe also older?
    I renew my thanks for your reply.
    User: "Jaehoon"
    Altair Employee
    Updated by Jaehoon
    Could you try "Parameter Sweep" with the attached dipole example?
    You might visit "Altair MarketPlace" to download  (different) Feko installation file.
    https://marketplace.altairone.com/Marketplace
    Thank you.
    User: "Jaehoon"
    Altair Employee
    Updated by Jaehoon
    Could you send your Feko model (.cfx) to me (jaehoon@altair.com) or here?
    I would investigate.
    Thank you.
    OP
    Of course yes, it's attached, but the problem is general, so it concerns every project.
    Is it possible that this problem regards the folder where I save the project?
    Thank you.
    User: "Mel"
    Altair Employee
    Updated by Mel
    We have found the problem, hopefully.
    The problem is using the "à" character in your filename or folder structure.
    Please remove this and try again.
