Hi,
Does anyone have a good step by step method of combining multiple components and their loads? I understand the concept of first creating a 2-D shell and then a 3-D (for me, tetra) mesh to finalize a component. My specific problem is that I am trying to simulate fluid flowing through a solid (like a pipe of water through a cube). My partner does the CAD, and he gave me two IGES files of the components (one being fluid, the other being metal). The IGES files for both are just the 'shell' surfaces for the two. I imported both geometries and began meshing. I created a 2-D mesh for the fluid, and one for the metal. Then I went to do tetramesh for each. I used the option 'per-volume-component' to create a solid mesh for the fluid and the metal separately. If I wanted to specify a constraint on the fluid shell nodes but needed it to interact with the shell and solid elements of the metal...how would I go about that? Does it do it automatically? This is where I'm stuck, so if anyone has any advice or can direct me to some help, I'd really appreciate it! Thanks.
Dylan Stelzer
