🎉Community Raffle - Win $25
Join and Win
Simulate bolt constraint
I want to simulate in Hypermesh the constraint, in a cilinder, due to the presence of bolts. To do this I created a geometrical node in center of the cilinder with a constraint of all 6 DOF, and then used rigid element (RBE2) to connect the node with all nodes in the surface of the cilinder, as shown in this picture:
<?xml version="1.0" encoding="UTF-8"?>post-37131-0-12631300-1432997870_thumb.p
results in Hyperview show a very strong vonMises stress in the external part of the cilinder. I think this result does not represent reality because the stress should be uniform along the bolt.
 <?xml version="1.0" encoding="UTF-8"?>post-37131-0-40080700-1432998307_thumb.p
there are other way to modeliza the interaction between structure and bolts?
thanks
1 - 2 of 21
