🎉Community Raffle - Win $25
Join and Win
Export a component into HM (both meshing & geometry)
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I see the command '*filewritecomponentgeometry' :
*filewritecomponentgeometry - This command allows you to export HyperMesh files on a per-component basis, so that you can export HM geometry that is part of a larger assembly without exporting the entire assembly.
I'm looking for another command allowing to export also meshing & geometrical data of one component into a HM model ?
Any idea for help ?
Thanks,
1 - 3 of 31
    Altair Employee
    OP
    Hi Q.NGUYEN-DAI
    At Present there is no command to output both mesh and geometry and *feoutput can only export the FE but not the geometry.
    I will raise a RFE to include this feature in future versions.
    Altair Employee
    OP
    Hi Pagadala,
    *feoutput exports into Solver input data. I not need that.
    It's so nice if we have something like *filewritecomponent to save all data (geometry & meshing) of one component into a HM file.
    For this moment, I have to delete all component except one and then do 'Save as' into a HM model file.
    Thanks,
    User: "Sergei"
    Altair Community Member
    Updated by Sergei
    Hi,
    Is it still no any function for export elements and geometry to the .hm file from one selected component (or several ) ? I tried to find but with no success unfortunately...
