Initial Angular Velocity for PSIM BDCM Block?
User: "Annalisa J."
Altair Community Member
Updated by Annalisa J.
Is there a way to set an initial angular velocity for the PSIM BDCM block (3-phase permanent magnet brushless dc machine with trapezoidal back emf)?
My goal is to simulate the motor response starting from while the motor is in motion (instead of starting from 0 RPM and accelerating up to the desired value).  I am using SimCoupler to run with input from MATLAB, and since the focus of the simulation is on behavior at much higher RPM, being able to specify the starting speed would be more efficient.
I am aware of the Save and Load flags, but that is not quite what I am looking for since it would require running the first part of the simulation to get those values, which is what I am trying to avoid.
Thank you for your help!
