🎉Community Raffle - Win $25
Join and Win
Error Geometry buiding
WendpangaUser: "Wendpanga"
New Altair Community Member
Updated by Wendpanga
Hello,
I have a error message when i try to buid the volumes of my geometry and in dont know why. Can you help me to fixe it?
i attached th screanshoot of the error messages.
Thank for your help
Best regards!
Fadel
1 - 6 of 61
    asoualmiUser: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    Can you share your Flu project.
    Best regards.
    OP
    Hi,
    Ok no problem.
    Thanks for your help.
    Best regards!
    Fadel
    Altair Employee
    Updated by asoualmi
    Hi,
    Sorry for the late answer. The problem comes from the geometry. When I do build volume, Flux display an error message:
    line 160 face 88 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.013 , 0.014 , 0.002435 )line 161 face 88 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.013 , 0.011 , 0.002435 )line 165 face 38 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.011 , 0.014 , 0.0022 )line 165 face 43 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.011 , 0.014 , 0.0023 )line 169 face 38 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.011 , 0.011 , 0.0022 )line 169 face 43 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.011 , 0.011 , 0.0023 )line 172 face 38 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.011 , 0.0022 )line 172 face 43 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.011 , 0.0023 )line 174 face 38 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.014 , 0.0022 )line 174 face 43 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.014 , 0.0023 )line 181 face 88 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.014 , 0.002435 )line 182 face 88 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.01 , 0.011 , 0.002435 )line 208 face 101 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.014 , 0.002585 )line 208 face 104 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.014 , 0.002485 )line 208 face 105 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.014 , 0.002385 )line 210 face 101 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.014 , 0.002585 )line 210 face 104 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.014 , 0.002485 )line 210 face 105 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.014 , 0.002385 )line 213 face 101 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.011 , 0.002585 )line 213 face 104 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.011 , 0.002485 )line 213 face 105 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03625 , 0.011 , 0.002385 )line 215 face 101 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.011 , 0.002585 )line 215 face 104 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.011 , 0.002485 )line 215 face 105 face line intersection :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20'> 0.03725 , 0.011 , 0.002385
    and when I check the faces (38,43,88,101,104 and 105), I found that there is intersection between faces and  lines.
    You need to correct the geometry to build the volumes.
    The Flux version that I use is Flux 2020
    Best regards.
    OP
    Hi,
    Thanks for the answer. I delete all the faces that creat the intersecions but it is still not possible to build the geometry. I use Flux 2019 and I don't have another error message besides the one I sent above.
    Best regards,
    Wendpanga Fadel BIKINGA
    Altair Employee
    Updated by asoualmi
    Hi,
    Did you install the 2020 version
    Altair Employee
    Updated by asoualmi
    Hi,
    Did you install Flux 2020 version? If it is the case, try to use check geometry?
    Send me your new Flu project.
    Best regards.
