*** ERROR # 827 ***
User: "seno"
New Altair Community Member
Updated by seno
FEM model for eigenvalue analysis was created with Femap with NASTRAN.
The file extension is dat.
However, the analysis at NASTRAN took a very long time.
So, I want to import this into HyperMesh, and perform eigenvalue analysis with Optistruct.
When I operated as shown, I got the following error:
<?xml version="1.0" encoding="UTF-8"?>solve.thumb.JPG.f4ce8aa71993bf2023ee9c4eb620ac74.JPG
*** ERROR # 827 ***
Invalid ASET run, PARAM,EXTOUT,DMIGPCH or
PARAM,EXTOUT,DMIGBIN must be specified for DMIG output.
How do I resolve the error?
Reference documents are more helpful.
Also, I want to perform frequency response analysis with Optistruct on the same model too.
The following is an excerpt of dat data.
INIT MASTER(S)
NASTRAN SYSTEM(319)=1
ID Neo66B,Femap
SOL SEMODES
TIME 10000
CEND
  TITLE = MSC/MD Nastran モード 解析セット
  ECHO = NONE
  MFLUID = 1
  DISPLACEMENT(PLOT) = ALL
  METHOD = 1
BEGIN BULK
$   Written by : Femap with NX Nastran
$   Version    : 11.1.1
$   Translator : MSC/MD Nastran
$   From Model : D:\Neo66BC_Hull-vibration_Standard.modfem
$   Date       : Mon Jul 14 08:00:18 2014
PARAM,POST,-1
PARAM,OGEOM,NO
PARAM,AUTOSPC,YES
PARAM,GRDPNT,0
EIGRL          1      .5     30.               0                    MASS
CORD2C         1       0      0.      0.      0.      0.      0.      1.+FEMAPC1
+FEMAPC1      1.      0.      1.
CORD2S         2       0      0.      0.      0.      0.      0.      1.+FEMAPC2
+FEMAPC2      1.      0.      1.
$ Femap with NX Nastran Constraint Set 1 : ASET
ASET           3     123
ASET       50126     123
$ Femap with NX Nastran Property 20108000 : Mat01_t8.0
PSHELL  20108000       1      8.       1               1              0.
ELIST          1  200001  200002  200003  200004  200005  200006  200007+
+         208872  208873  208874  208875  208876  208877
$ Femap with NX Nastran Region 1 : 無題
MFLUID         1       0   5375. 1.025-9       1               N       N
ENDDATA
1 - 5 of 51
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    NX Nastran (Femap) has some different card comparing to Altair's Optistruct. So you have to do attention to this conversion.
    User: "FaroukM"
    Updated by FaroukM
    Hey,
    Try to import your *.dat file using :
    Then redefine your configuration : Eigenvalues solver ..... and then solve them with OptiStruct.
    If the model is large (you have a lot dof), try to use AMSES solver instead of Lanczos
    Cheers,
    User: "seno"
    OP
    Updated by seno
    Tank you reply.
    Import *.dat file and save as test.hm file
    Add cmsmesh
    Save as test.fem file and solve with optistruct
    <?xml version="1.0" encoding="UTF-8"?>4.thumb.JPG.5ee3490e1b295eb414296253ade968cb.JPG
    So, this fatal error appeared
    The following is an excerpt of fem data.
    $$ Optistruct Input Deck Generated by HyperMesh Version  : 2017.2.0.16
    $$ Generated using HyperMesh-Optistruct Template Version : 2017.2
    $$   Template:  optistruct
    $$ optistruct
    TITLE = MSC/MD Nastran    [ h   Z b g
      METHOD(STRUCTURE) =        1
      MFLUID =        1
    $$                      Case Control Cards                                      $
    INIT MASTER(S)
    ID Neo66B,Femap
    SOL SEMODES
    TIME 10000
    CEND
    ECHO = NONE
    $$ HYPERMESH TAGS
    $$BEGIN TAGS
    $$END TAGS
    BEGIN BULK
    $$  Stacking Information for Ply-Based Composite Definition
    ASET       50109     123
    ASET       50126     123
    $$  MFLUID cards
    $HMNAME LOADCOL                2'MFLUID2'
    $HWCOLOR LOADCOL               2       4
    MFLUID         2       0  5375.0 1.025-9       1               N       N
    +         1.0+10
    $$  CMSMETH cards
    $HMNAME LOADCOL                4'CMSMETH'
    $HWCOLOR LOADCOL               4       4
    CMSMETH 4       CB      30.0                       AMSES
    ENDDATA
    $$        Data Definition for AutoDV                                            $$
    $$        Design Variables Card for Control Perturbations                      $$
    $$        Domain Element Definitions                                            $
    $$            Control Perturbation                                              $$
    User: "PrasannaK"
    Altair Employee
    Updated by PrasannaK
    Hi,
    Can you share the .out file?
    Thank you
    User: "seno"
    OP
    Updated by seno
