Altair RISE
Nominate Yourself Now!
Rıgid body
User: "durukanbdilek"
Altair Community Member
Updated by durukanbdilek
hi I have a model to calculate frf for TPU materials between two metal plates
I would you like to convert metal plate from deformable to rigid how to perform it?
1 - 17 of 171
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi
    Check this video.
    OP
    I checked but where only applied to hole on plate
    how to applying to my model rbe element
    User: "Pranav Hari"
    Hi durukanbdilek
    Similarly, you can switch on calculate node and multiple node option and select all the nodes of the plate which you want to make as a rigid.
    The master node will be automatically calculated.
    Hope it is clear
    OP
    in my problem without using contact how to mesh ?
    User: "Pranav Hari"
    Hi durukanbdilek
    Can you please explain more about your requirement with some images or so
    OP
    actually I have 2 main problem in model shared as above
    firstly without defining contact and any dublicated node how to mesh the geometry
    and I have not able to convert to plate rigid body yet
    OP
    My aim is to calculate Transmissibility FRF function and compare with experimental results
    User: "Pranav Hari"
    Hi durukanbdilek
    You can right click on Model Browser>> Create>> Rigid body. Make sure you go through the Rbody card on OptiStruct help before you create as it gives a fair idea on what is required for Rbody.
    The file has been edited and attached. Also, an example file is attached which you can use as a reference
    Since you have already given  node to node connectivity between the honey comp material and plate, a need for an additional contact is not there
    OP
    a last question to you about shell thickness
    you know modelled top and bottom plate were modelled using shell
    how a shell thickness ofsett selection used in model
    also I opened edited file and saw nothing about rb
    User: "Pranav Hari"
    Hi durukanbdilek
    you can see 2 Rbodies created in the edited file. The above-shared video explains the creation of Rigid body using Radioss user profile. Since you are using OptiStruct user profile, you need to create likewise.
    Also, refer online help for more details regarding shell thickness offset
    OP
    I think you use newer version of hypermesh than mine therefore I cannot see them
    User: "Pranav Hari"
    Which version of Hypermesh are you using?
    OP
    Altair hyperworks 14
    User: "Pranav Hari"
    Hi durukanbdilek
    I recommend you to update the version
    OP
    hello can you shell - solid connection with rbe element if you say yes how _?
    OP
    have a vibration isolation model, as below picture, blue, green and pink part represents shaker table, specimen and constant mass, respectively
    I would like to assume blue and pink component as rigid how to perform it ? and Do I need to assign a material card to these components?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.ec4f7c92eb9349686b20260c0c5a5247.png
    User: "yehoo"
    Updated by yehoo
    Hi ,
    I think you can create a new material with high young modulus(E-Modul) value. This would mean the component is rigid.
    or another method to save some calculation time, create a 2d mesh for the components(Pink and blue) and define rigid body for both of them.
