actually I have 2 main problem in model shared as above
firstly without defining contact and any dublicated node how to mesh the geometry
and I have not able to convert to plate rigid body yet
You can right click on Model Browser>> Create>> Rigid body. Make sure you go through the Rbody card on OptiStruct help before you create as it gives a fair idea on what is required for Rbody.
The file has been edited and attached. Also, an example file is attached which you can use as a reference
Since you have already given node to node connectivity between the honey comp material and plate, a need for an additional contact is not there
you can see 2 Rbodies created in the edited file. The above-shared video explains the creation of Rigid body using Radioss user profile. Since you are using OptiStruct user profile, you need to create likewise.
Also, refer online help for more details regarding shell thickness offset
have a vibration isolation model, as below picture, blue, green and pink part represents shaker table, specimen and constant mass, respectively
I would like to assume blue and pink component as rigid how to perform it ? and Do I need to assign a material card to these components?
Hi
Check this video.
