The cause of error
To whom it may concern,
I created the circuit model as below, but the simulation cannot be performed due to the following error.
The element SCB1 is the C-block whose output is given to the voltage-controlled voltage source.
Could you tell me the cause of error? What's wrong with this model?
If you have any questions, please feel free to ask me. Also, if you need this file, I can send it to you.
Thank you in advance.
Best regards,
Yoshiki Hane
Dear Rhonda,
Thank you for your kind reply.
I'm sorry for the late reply, I've been busy.
The PSIM schematic and two CSV files are zipped.
The CSV files are used in the C-block (SCB1), as written in the 126th and 127th lines.
So, when analyze this schematic, please store the CSV files in the path written in the 126th and 127th lines, or change the path name in the C-block.
Best regards,
Yoshiki Hane
Hi, Yoshiki,
Please send us your PSIM schematic. The picture doesn't provide sufficient information.
You may zip the PSIM schematic when attach it to this question.
Sincerely,
Rhonda
