Function "Find" an element via ID in Hyperview
Hallo,
is there in Hyperview a function to find an Element via ID? I am thinking about a function like the function 'Find' (or find entities) in Hyperworks, where you can find entities with the ID-number.
I want to check if the measurment points still are on the correct locations. However I couldn´t find any button for this funktion.
Thank you
Hi Martinwho,
You can try this using the Query option in HyperView, where this panel will allow users to view information on nodes, elements etc contained in the active model. Here you can view the element by providing the element id.
