🎉Community Raffle - Win $25
Join and Win
Altair Inspire Initialization Failure
User: "Sameul Zimmerman"
Altair Community Member
Updated by Sameul Zimmerman
Upon launching I receive the following error
Error loading C:/Program Files/Altair/2023/Inspire2023/hwx/plugins/freedom/gui/win64/bin/hwfdmplugin.dll: A dynamic link library (DLL) initialization routine failed.
I've tried uninstalling and reinstalling. I also cannot find any help or related problems. Any help would be greatly appreciated.
1 - 15 of 151
    User: "MilanRaval"
    Altair Employee
    Updated by MilanRaval
    Hello Samuel,
    There is a fair chance that one of the important DLLs is being deleted from that folder during installation by anti-virus. Can you try re-installing the tool with Antivirus on off mode?
    User: "Dean Charles"
    Updated by Dean Charles
    Hi Samuel
    What is you compute hardware configuration, CPU model, RAM and Graphics hardware?
    cheers
    User: "Thomas_21776"
    Updated by Thomas_21776
    Hi everyone,
    I have the same problem than the one describe above.
    I try to run Inspire on a Windows 11 Parallels virtual machine with a MacBook Air M3.
    I checked the files and "hwfdmplugin.dll" is not deleted. I also tried to uninstall and reinstall Inspire, it doesn't change anything.
    Do you have any idea of solution ?
    Thanks.
    Thomas
    User: "NT_20733"
    Updated by NT_20733
    I have exactly the same problem. Does anyone know of a solution?
    User: "MilanRaval"
    Altair Employee
    Hello NT,
    What version of Inspire do you have and did you check if the dll mentioned above is there in the location?
    Regards,
    Milan
    User: "MilanRaval"
    Altair Employee
    Hi everyone,
    Thanks.
    Thomas
    Hello Thomas,
    Regards,
    Milan
    User: "Valentine"
    Updated by Valentine
    Hello,
    I have the same problem and the file is in the indicated location. I have Inspire version 2023.1.
    I also have another PC on which to install inspire but I don't know how to request a new licence because I can't repeat the first step described here : https://web.altair.com/altair-student-edition
    because I've already created an account using my university email address.
    Thank you,
    Valentine
    Can everyone that's having this problem post what brand (AMD or Intel), model and stepping of CPU and Graphics card you are using.
    User: "zhao solaren"
    New Altair Community Member
    Updated by zhao solaren
    Hi:
    I have the same problem and the file is in the indicated location. I have Inspire version 2023~2024.
    I also have another PC on which to install inspire.It's OK!
    Why?
    User: "HyderPatel"
    Updated by HyderPatel
    I also experencing same issue with InspireForm 2023.1. do you have any solution for this .
    User: "Abdulsamad Popoola"
    Updated by Abdulsamad Popoola
    I'm having the same error
    8gb ram Dell laptop with UHD graphics
    User: "Chayan"
    Altair Employee
    Updated by Chayan
    Folks,
    At present Inspire Form is not officially supported on Macs with M Series CPU and Parallels.
    User: "mcampano10"
    yo tengo el mismo problema ,
    C:/Archivos de programa/Altair/2023/Inspire2023/hwx/plugins/freedom/gui/win64/bin/hwfdmplugin.dll
    Intel(R) Core(TM) i5-3320M CPU
    ram 8,00 GB (7,87 GB usable), Sistema operativo de 64 bits, procesador basado en x64
    WINDOWS 10 PRO,
    ALTAIR 2024.4
    NO SE QUE HACER ,, HE ECHO DE TODO ,PERO NO SE PUEDE
    User: "Tev"
    I don't know if this problem has been solved but ive currently run into this same problem when launching Inspire on InspirePersonal 2024.1.1 and Inspire 2025
    Error loading C:/Program Files/Altair/2025/Inspire2025/hwx/plugins/freedom/core/win64/bin/hwfdmplugin.dll: A dynamic link library (DLL) initialization routine failed.
    Hardware/Software Configuration:
    Windows 10
    Intel® Xeon E5-2697 64GB ram
    NVIDIA Geforce GTX Titan 6.0GB
    A similar thread suggested setting setting High Performance graphics settings for AMD and NVIDIA GPU's (https://community.altair.com/discussion/60552/failed-to-open-inspire-2024-1-1). This option didn't work for me. I even switched out graphics cards to a GeForce GTX 1060 6.0GB.
    I notice that the dynamic library is present located in the correct place. Could this be an system environment variable that hasn't been set?
    User: "MilanRaval"
    Altair Employee
    Hi All,
    For those who are facing Inspire Crash issues, There are couple of things to investigate.
    1. See if the file missing is being blocked by Anti-virus of your system or somehow getting black listed by security system. Your IT can help to find out through log files.
    2. Try to update remaining crucial windows updates and update your graphics drivers to latest before Installing Inspire.
    3. If your system CPU/Graphics Hardware is outdated and does not support Vulkan graphical functionality, it will likely to be crashed.
    4. Consider doing clean installation of your graphics drivers. (Mentioned in below link)
    check this system requirements,
    https://2024.help.altair.com/2024.1/inspire/en_us/topics/shared/unity_basics/system_requirements_st_r.htm
