🎉Community Raffle - Win $25
Join and Win
Delete part of a solid
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey guys,
is there a way to only delete part of a solid? Which means only part of a solids geometry. Unfortunately my model neither has a surface, nor lines. Only solid.
If that's not possible, is there way to 'reverse transform' a solid into a surface and subsequently a surface into lines?
Of Course remodelling the whole model from the very begining starting with the 1D level would work, but I'd like to avoid that.
Kind regards,
Niclas
1 - 5 of 51
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Solid part must have lines.You can use solid edit option to edit soild part.You can create solid from enclose surfaces.
    Soild : Bounding surfaces
    Altair Employee
    OP
    If I delete the solid of my component, there are no lines left afterwards. So obviously a solid part must not always have lines.
    I tried solid edit already...boolean & detach. neither of them worked for my issue.
    Is it possible to only delete a specific part of a solid within one component?
    It would be nice if you could share model file and screenshot where you want to trim part.
    Altair Employee
    OP
    Okay sry it was a misunderstanding of my site. What I tried to delete was a part of a solid, which I deleted before by using the boolean Operator (A-B).
    Therefore I only saw the lines, which defined the hollow volume, which is misinterpreted as part of the solid. That's why I couldn't delete it.
    By deleting all solids only the surface remained, which was actually there after all. Thanks for your effort and sorry for the confusion.
    Thanks for the update.
