Altair RISE
Nominate Yourself Now!
How to change thickness of a 3D Mesh?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi All,
I have a 3D mesh composed of hex elements of a component that looks like a human rib.  How can I change the thickness of this 3D mesh in an effecient way?  For example, if want the increased the thickness of this component by 10%, what are some to accomplish this? This mesh does not have any surfaces associated with it.
So far, I have been translating the nodes of the 3D face elements along a vector to increase the thickness and I am curious if there is a better way.  Any help will be appreciated!
Cheeres,
Sriram
1 - 5 of 51
    Altair Employee
    OP
    Hi Sriram,
    Have you tried HyperMorph module in HyperMesh?
    You can try HyperMorph.
    Altair Employee
    OP
    Hi Prakash,
    I have not tried HyperMorph.  How can I access this?  Also, is there a way to accomplish this in Hypermesh?
    Sriram
    Altair Employee
    OP
    Sriram,
    Goto Tool page>> HyperMorph to access HyperMorph.
    There are tutorials available on help for HyperMorph.
    Altair Employee
    OP
    Hi All,
    Cheeres,
    Sriram
    Could you share a simple model?
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi, you can use scale (panel tool>scale) in normal direction of rib, (set scale factor of that direction is 1.01 mean 10%thicker, other factor keep 1.0)
    but be sure that normal direction is same as x y z direction of global or created local system
    Using Hypermorph is OK also
