🎉Community Raffle - Win $25
Join and Win
Select elements from a set of nodes
vipin_22401User: "vipin_22401"
Altair Community Member
Updated by vipin_22401
Hi all,
Is there any direct api to select elements from a set of nodes?( For example in the image i need the highlighted elements, dont need the adjacent elements to be selected.)
I tried *findmark and *createmark which are selecting the nearby elements too.
1 - 6 of 61
    tinhUser: "tinh"
    Updated by tinh
    Hi Vipin
    You can ignore adjacent elems
    *createmark nodes 1 {*}$NodeList
    *createmark elems 1 'by node' {*}[hm_getmark nodes 1]
    *createmark elems 1 reverse
    *appendmark elems 1 'by adjacent'
    Another solution you can try is the following:
     hm_createmark nodes 1 'by id only' $NodeList; hm_createmark nodes 1 advanced reverse; hm_createmark elems 1 'by nodes' [hm_getmark nodes 1]; hm_getmark elems 1;
    OP
    Nice trick @tinh, @akitoguc :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    Works for me!
    Just another way to handle this....
    *createmarkpanel nodes 1 'Select nodes to which the attached elements have to be determined'
    eval '*createmark elems 1 \'by nodes\' [hm_getmark nodes 1]'
    eval '*createmark nodes 2 \'by elems\' [hm_getmark elems 1]'
    *marknotintersection nodes 1 nodes 2
    eval '*createmark elems 2 \'by nodes\' [hm_getmark nodes 1]'
    *markdifference elems 1 elems 2
    set attached_elem_list [hm_getmark elems 1]
    tinhUser: "tinh"
    Updated by tinh
    Oh, many ways...
    @vipin should test which one is the fastest
    Using cmd
    time {script}
    To measure time to finish a script
    OP
    @tinh
    Tested all methods, last one runs faster on bigger assemblies (saves around 5 sec ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' /> ).
    Thanks again all!
