Sir i am working on erossive ware analysis project. So i want to know that is it possible with radioss? And what type of interface is needed to have errosive ware between two object?
Looks like we currently don't support wear simulation.We will update you once it is available in future version.From your doc i see it is possible with LS Dyna solver hence requesting you check same with LS Dyna support.
You can prepare deck for LS Dyna using Hypermesh. All the relevant cards would be available with LSdyna user profile.Since you would be using Ls dyna solver we request you to check interface information from Dyna support or Help files.
Could you share some more info for the type of analysis?
Regards
Rahul R
