Altair RISE
Nominate Yourself Now!
simulation problem with coupling between two cables
User: "Sam_21831"
Altair Community Member
Updated by Sam_21831
Hello,
I am testing the coupling between two cables but the simulation results show a significant differences with the measurement data.
Please find model and measurement results attached.
1 - 9 of 91
    User: "Torben Voigt"
    Altair Employee
    Updated by Torben Voigt
    Hi Sam,
    I believe that it is recommended to use only one harness and only one cable path in case of strong coupling of neighboring (and parallel) cables. Could you try that?
    Best regards,
    Torben
    User: "Sam_21831"
    OP
    Hi Sam,
    Best regards,
    Torben
    Hi Torben,
    Could you explain this better?
    Sam
    Altair Employee
    Hi Torben,
    Sam
    Hi Sam,
    I was thinking of having only on cable path, one cable bundle (source and victim cable) and one harness. The distance between the cables can be defined in the bundle:
    The harness would look like this:
    I attached the edited model (Feko version 2023.1.1).
    Best regards,
    Torben
    User: "Sam_21831"
    OP
    Hi Sam,
    Best regards,
    Torben
    Hi Torben,
    Thank you for help and support. I used what you have recommended but still realize big differences between Feko simulation results and the measurement data.
    For example, this is the comparison between SIM and EXP for 0.5 in. spacing
    Regards,
    Sam
    User: "Sam_21831"
    OP
    Hi Torben,
    Regards,
    Sam
    Hi Torben,
    One more thing, I have tried to test the unshielded cables. I realized at 1MHz (as an example) that the calculated voltage across the victim resistor (in mV) is about 25.97 but for the previous test (one cable is shielded) the voltage is 46.29 mV. This is unexpected as this value should be less.
    Thanks,
    Sam
    Altair Employee
    Hi Torben,
    Thanks,
    Sam
    Hi Sam,
    The model I attached yesterday (shielded_one_harness_one_cable_path.cfx) is based on your model in the shielded_0p02 folder. The distance between the cables is 0.0015424 m = 0.0607 inch. I don't find a related result in your .xlsx file.
    To reduce complexity, could you please attach one model here with related measurement data?
    I quickly tested shielded vs. unshielded and the voltage is as expected:
    Best regards,
    Torben
    User: "Sam_21831"
    OP
    Hi Sam,
    Best regards,
    Torben
    Hi Torben,
    Thank you again for your help. Here are attached the case of shielded and unshielded cables I was testing on Feko with a separation distance of 0.5 in. (please note that this distance is taken from the outer radius of the cable plus the coat thickness). I also, provided an excel sheet for the corresponding measurement data where I don't see an agreement between both resulted numbers.
    Thank you
    Regards,
    Sam
    Altair Employee
    Hi Torben,
    Thank you
    Regards,
    Sam
    Hi Sam,
    I get quite good agreement when dividing your measured voltage in the victim cable by 2 (your values are peak-to-peak, Feko uses peak values!) while still keeping 3 V as source:
    This is a bit surprising indeed, since I would think that I'd have to use 1.5 V as source.
    I will investigate further.
    Best regards,
    Torben
    Altair Employee
    Hi Sam,
    Best regards,
    Torben
    Hi Sam,
    Since the problem you are having is also being dealt with in a support case by my colleague Shannon Mistry, I would suggest that we put this on hold. If you have a solution from Shannon, perhaps you could post it here so that the community can benefit from it?
