Altair RISE
Nominate Yourself Now!
Error When Automating Measurments in Feko with some objects already present
Sasha1296User: "Sasha1296"
Altair Community Member
Updated by Sasha1296
Hello
I am working on a project where this time there is an aluminum cube shell and an spiral antenna present in the FEKO model file.  I am trying to simulate lots of configurations of a perfect electrically conductive cube inside the aluminum cube shell by generating a random cube (random length, random x, y, z coordinates).
Before I had a different simulation where nothing was present originally in the model and I got it to run, however this time I am getting an error I suspect it has something to do with the objects present in the model before the cube is generated:
'84: Error 16271: Empty expression is not allowed for Segment size.
Error 16628: Error in expression at position 0 for expression: Segment size = '
I'm not sure how to fix this
1 - 2 of 21
    MadeléUser: "Madelé"
    Altair Employee
    Updated by Madelé
    You are not setting the custom mesh properties correctly. Use macro recording to see the scripting equivalent of the custom mesh settings you would like to define.
    OP
    Thanks for the suggestion!
    I got it to work
    I actually didn't know anything about macros before, but now I realize it's a pretty useful tool
