🎉Community Raffle - Win $25
Join and Win
Displacements in a DTRAN Solution
User: "mpvnaresh"
Altair Community Member
Updated by mpvnaresh
Hi all
 In a Direct Transient solution i have given a acceleration load with certain frequency and amplitude.
When  icheck displacements in the location where acceleration is applied, The Displacement curve is a not oscillationg one.Instead it is keep on going.
Can any one help me in getting the oscillating displacements.
I have tried by changing all options of FORM(1) in Displacement output request.but no use.
Please help me in this .
1 - 17 of 171
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Did you specify damping in your model?
    User: "mpvnaresh"
    OP
    Yes Sir ,
    I specified
    User: "mpvnaresh"
    OP
    This is not only the model , for all DTRAN analysis i am facing the same problem.
    Could you please share the .fem and .out file of the run of any simplified model with this issue?
    User: "mpvnaresh"
    OP
    User: "mpvnaresh"
    OP
    Sir
    Kindly let me know if any other  information is needed.
    User: "mpvnaresh"
    OP
     sir ..any update ?
    Can you give a try with time Vs disp instead of time Vs accel?
    User: "mpvnaresh"
    OP
    Sir
    with displacements as input load it is oscillating .But the question remains same.
    If i convert it into displacements obviously it oscilates as we are giving displacement directly.
    But my load case is in acceleration i need to apply it in accelerations only.
    Could you please consider initial velocity for the base setup where you have time Vs accel.Transient initial conditions are defined using a TIC Bulk Data Entry. Initial displacements and initial velocities can be defined. This should help you to avoid drift in the displacement plot and get oscillating plot.
    User: "mpvnaresh"
    OP
    Thanks For the response .
    I will try this and update you .
    User: "mpvnaresh"
    OP
    Sir
    I am not able to give Input of Initial conditions . Can you please help in how to do this?
    How to create TIC Bulk data entry. And also i have no data for initial displacements and initial velocities then how to get those values.
    I got help from my colleague to calculate the initial velocity based on the given acceleration curve.I remember we provided initial velocity of -624.0 and with that we got proper oscillating plot.Attached is the fem file.
    User: "mpvnaresh"
    OP
    Sir
    I really Appreciate this.
    Thanks a lot for your time.
    I think this is solved.
    But when try to integrate the acceleration curve to get celocity i am gettion a Zero velocity. Please help me in the methodology for getting velocity.and also how did you created TIC (V).
    When i go go to load type page Velocity type is Blank.
    Thanks again for the support sir.
    TIC V you can create from constraints panel & set the load type to TIC V.Sorry i cant provide you right now the hand calculation which we did to calculate Intial velocity,  as i am away from office desk.However,I do have the math we performed in HyperGraph to crosscheck.PFA mvw file for same,
    User: "mpvnaresh"
    OP
    Thanks Sir
    User: "mpvnaresh"
    OP
    Sir
    I calculated Initial Velocity and applied as TIC(V).
    But after the compltio of acceleration cycle displacements are cumulative.
    (which mathematically  may true, As Acceleration=0,  Velocity which is integral of Acceleration = constant , Then Displacement is a straight line which is cumulative )
    How can we make the  velocity, displacement to be zero after the load (Acceleration)is removed .
