Hi expert,
I have some questions:
Best Regards
Hello Pham,
For your
Q1 ) As suggested in the training slide. It is better to use Investment or High-Pressure Die casting as your wall thickness is 0.022 inches <0.025 inches. However, apart from the guideline you can use a different method as required. This can become an exceptional case based on the other three parameters mentioned in the training material. (Material, Cost, surface finish). Another factor that plays a crucial role in design.
Q2) You are not bounded to use a minimum of 3 layers of mesh to perform simulation and obtain results. But it is recommended as a minimum criterion to obtain results with higher accuracy.
Hope these answers help.
Regards,
Milan Raval
Hi Milan Raval,
Thank you for your help.
