🎉Community Raffle - Win $25
Join and Win
Tetra Mesh - Parameters String
Hi all,
I have a question after reading the documentation:
for tetra meshing using tcl command *tetmesh the script needs to use strings containing various mesh controls and parameters, e.g. 'tet: ...', '2d: ...', 'size_ctrl: ...', and 'pars: ...'
I am using following parameters in the last string 'pars':
 'pars: vol_skew=0.8  tet_clps=0.2  aspect=6 Skew=30 vol_ar=5'
However, when I run the script, Hypermesh simply fails to recognize this string, and terminates image/emoticons/default_sad.png' alt=':(' srcset='/emoticons/sad@2x.png 2x' width='20' height='20'>
*createstringarray 2  'tet: 35 $growth_rate 2 $max_size 0.8 2 0' '2d: $elem_order $elem_type 1 $elem_size_2d $min_size_2d 30 1' 'pars: vol_skew=0.8  tet_clps=0.2  aspect=6 Skew=30 vol_ar=5'
*tetmesh solids 1 0 elements 0 -1 1 3
For further reference kindly see the online documentation about tetmesh:
http://www.altairhyperworks.com/hwhelp/Altair/hw12.0/help//hwdref/hwdref.htm?_tetmesh.htm
Anyone with some hints to the reasons for failure of this string, kindly help.
Best regards,
Mubeen.
1 - 2 of 21
    tinhUser: "tinh"
    Altair Community Member
    Updated by tinh
    hi Mubeen
    your string array has 3 strings
    so try replace '*createstringarray 2' to '*createstringarray 3'
    Hi tinh,
    thanks for the reply, I replaced ' *createstringarray 2' with '*createstringarray 3', but the problem is not resolved image/emoticons/default_sad.png' alt=':(' srcset='/emoticons/sad@2x.png 2x' width='20' height='20'> i.e.
    *createstringarray 3  'tet: 35 $growth_rate 2 $max_size 0.8 2 0' '2d: $elem_order $elem_type 1 $elem_size_2d $min_size_2d 30 1' 'pars: vol_skew=0.8  tet_clps=0.2  aspect=6 Skew=30 vol_ar=5'
    doesn't work either.
    I tried something strange, instead. I appended the quality parameters string directly to the *tetmesh command
    *tetmesh solids 1 0 elements 0 -1 1 2 'pars: vol_skew=0.8  tet_clps=0.2  aspect=6 Skew=30 vol_ar=5'
    This way, there is no error shown by Hypermesh, but I am not sure if the string parameters were used by Hypermesh during the meshing.
    hi Mubeen
