Substring Command
User: "Batuhancoskun"
New Altair Community Member
Updated by Batuhancoskun
Hello,
I want to use substring function in compose. For Example:
 Input : str  = 'GeeksForGeeks'         str.Substring(5); Output: ForGeeks
But I don't know its command in Compose. How can I cut string ?
1 - 2 of 21
    User: "manoj kandukuri"
    Altair Employee
    Updated by manoj kandukuri
    Hi Batuhancoskun,
    As your variable 'str' is a string, you can get desired output by using indexing to get the 'letters' form the string
                --> str(6:end)
               output: ForGeeks
    if you want to split a string at a desired character/delimiter  you can use 'strplit', 'regexp'  functions.
    Hope this helps :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    OP
    My problem solved. Thank you for your answer. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
