Altair RISE
Nominate Yourself Now!
Seems to be an issue with compatibility of PMSM (FluxMotor) block with LUTs exported from FluxMotor 2023
User: "Chris L_22616"
Altair Community Member
Updated by Chris L_22616
Since exporting LUTs (lut_maps.mat) from FluxMotor 2023, I am getting this error in PSIM with the PMSM (FluxMotor) block: "Name: LKUP3D_MAT Can not find GRAPH_output axis: LOSS_IRON in Graph file"
1 - 10 of 101
    User: "NikosDimitrakopoulos"
    Altair Employee
    Updated by NikosDimitrakopoulos
    Hi Chris,
    Thanks for reaching out!
    At which stage of your workflow did this error occur?
    Did it happen immediately upon starting the simulation? -> possibly an import issue
    Or did it occur while the simulation was running? -> possibly a problem with the working range
    BR,
    Nikos
    OP
    Hi Chris,
    BR,
    Nikos
    Hi Nikos
    It occurs immediately upon starting the simulation. It seems that the export of the iron loss components has changed for FluxMotor 2023.
    Thanks
    Chris
    User: "Yongjun"
    Updated by Yongjun
    I checked that the same error occurred.
    The error message is the same.
    Altair Employee
    Hi Nikos
    Thanks
    Chris
    Hi Chris,
    Looks like an error in the process of the .mat file generation from Flux. Is this specific to FluxMotor 2023? Can you get this to work with version 2022.3?
    BR,
    Nikos
    Altair Employee
    Thanks for sharing this! Is this a FluxMotor 2023 related issue for you too?
    BR,
    Nikos
    User: "Yongjun"
    Updated by Yongjun
    BR,
    Nikos
    So am I.
    There was a problem with Flux Motor 2023.
    I haven't tried the 2022 version yet.
    OP
    Hi Chris,
    BR,
    Nikos
    Hi Nikos
    Yes, seems specific to FluxMotor 2023. It worked fine for me previously.
    Regards
    Chris
    Altair Employee
    Thanks everyone for your feedback on this. It seems to be a bug with FluxMotor v2023.
    I will make sure to document this issue in order to get that fixed.
    Best regards,
    Nikos
    User: "Gabriele_De_Boni"
    Updated by Gabriele_De_Boni
    I'd like to report the same issue. Please let us know if it will be fixed. Thank you
    Altair Employee
    Hi all,
    I'm getting in touch to offer a workaround for this issue. FYI we anticipate it will be resolved in FluxMotor 2024.
    It seems the issue is due to a difference in the name of "iron losses" and "torque" headers.
    With FluxMotor 2022.3 it was LOSS_IRON
    with FluxMotor 2023, it is LOSS_IRON_STATOR.
    ______________________________________________________________________
    With FluxMotor 2022.3 it was TORQUE
    with FluxMotor 2023, it is ELEMENT_TORQUE_ELECTROMAG.
    _______________________________________________________________________
    As a workaround, you can open the .mat file exported from FluxMotor using Compose and the MAT Explorer tool. From there, you can rename the headers accordingly. Once modified, you should save the altered file using the save('path/name.mat') command.
    BR,
    Nikos Dimitrakopoulos
