Displacement relative to nominal geometry
Hi,
I'm using HyperView for postprocessing of Ansys results. Within Ansys I'm modelling a thermal cooling process where the geometry shrinks due to negative thermal expension.
Is it possible to view the displacement in x-,y-.z-direction relative to the nominal (meshed) geometry instead versus a coordinate system?
Kind regards,
Thomas
1 - 1 of
11
Hi,
if you post a displacement contour plot, then the values are relativ to the nominal structure (but of course in global coordinates).
Best Regards,
Mario
