Altair RISE
Nominate Yourself Now!
How to get circumferential grids by selecting a node using TCL
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I have a meshed cylinder (2d) on which i want to give an option to select a node to user. Once the node is selected, and clicked on proceed button it should display all the circumferential grids having a user defined number to the grids. Let's say i select a grid having ID as 122. Now, i want to display all the circumferential grid starting from 123 on the same station location where user has picked the node. I want to do it using TCL/ TK.
Thanks
31 - 37 of 372
    User: "tinh"
    Altair Community Member
    Updated by tinh
    The reason is... you changed assumption :wacko:/emoticons/default_wacko.png' title=':wacko:' />
    I just give assumptions as mesh is a cylinder (you have multiple cylinders with different diameter), and mesh is quad only, equally (you give a mesh that not equally quad)
    User: "tinh"
    Updated by tinh
    If you posted above photos from starting, I would know that you have a variable tube mesh
    this proc will work with variable tube mesh (any quad-only tube mesh pattern generated by line drag)
    But it may not work if the tube has free edge or is shared nodes with other component!
    it must have 2 loops and isolated from other components!
     proc ::p_SelectCircumferentialNodes {{PreselectedNodeId {}}} { 	if {![hm_entityinfo exist nodes $PreselectedNodeId]} { 		*createmarkpanel nodes 1 'Pick a node on cylinder:' 		if {[hm_marklength nodes 1]!=1} return 		set PreselectedNodeId [hm_getmark nodes 1] 	} 	*createmark elems 1 'by node' $PreselectedNodeId 	*appendmark elems 1 'by attached' 	if {[catch {*findloops elems 1 0}]} { 		return -code error 'not valid cylinder' 	} 	if {![hm_entityinfo exist comps ^loops -byname]} { 		return -code error 'not valid cylinder' 	} 	hm_blockredraw 1; *entityhighlighting 0; hm_blockmessages 1 	*nameview 1 'p_SelectCircumferentialNodes' 	*saveviewmask '1' 0 	*displaynone 	*displaycollector comps on ^loops 1 1 	set LoopElems [hm_elemlist id ^loops] 	*createmark elems 1 [lindex $LoopElems 0] 	*appendmark elems 1 'by attached' 	set Loop1 [hm_getmark elems 1] 	*findmark elems 1 1 1 nodes 0 2 	if {[hm_checkmark nodes 2 $PreselectedNodeId]} { 		set Result [hm_getmark nodes 2] 	} else { 		*createmark nodes 1 'by comp name' ^loops 		*markdifference nodes 1 nodes 2 		if {[hm_checkmark nodes 1 $PreselectedNodeId]} { 			set Result [hm_getmark nodes 1] 		} else { 			*restoreviewmask '1' 0 			eval *createmark elems 1 $Loop1 			eval *createmark nodes 1 {'by elem'} $Loop1 			while 1 { 				*appendmark elems 1 'by adjacent' 				eval *createmark nodes 2 {'by elem'} [hm_getmark elems 1] 				if {[hm_checkmark nodes 2 $PreselectedNodeId]} { 					*markdifference nodes 2 nodes 1 					set Result [hm_getmark nodes 2] 					break 				} else { 					eval *appendmark nodes 1 [hm_getmark nodes 2] 				} 			} 		} 	} 	*clearmarkall 1;*clearmarkall 2 	*restoreviewmask '1' 0 	hm_blockredraw 0; *entityhighlighting 1; hm_blockmessages 0 	eval *createmark nodes 1 $Result 	hm_highlightmark nodes 1 h 	set Result }
    Altair Employee
    OP
    Hey Tinh,
    Thanks for your valuable response. It works perfectly for even different components. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    I have one thing to ask, how can i modify this code for including axial as well as radial tolerance.
    User: "tinh"
    Updated by tinh
    Forget tolerances. Above proc work with any axial or radial tolerance
    But it may be slower than the fisrt proc
    Altair Employee
    OP
    yeah but actually i have to put two options for user just in case there are two set of rings on the same axial location (Example a flange on the edge)
    if user selected option 1, it should give me both the rings
    or if 2, then only single.
    Apart from that, if we have some elements perpendicular to the cylinder elements, based on radial tol. i want to control the selection.
    User: "tinh"
    Updated by tinh
    Do it your self based on my proc
    Dont ask everything
    Altair Employee
    OP
    Dont ask everything
    I'm trying myself wanted to get a suggestion. Thanks for your help.
31 - 37 of 372
