🎉Community Raffle - Win $25
Join and Win
Morphing 2D Elements
DhairyasheelUser: "Dhairyasheel"
Altair Community Member
Updated by Dhairyasheel
Hi All,
I am trying to do morphing 2D elements to a surface.
 But unable to do so.
Can anyone please help?
Best Regards,
Dhairyasheel Desai
1 - 3 of 31
    savesaganUser: "savesagan"
    Updated by savesagan
    please give more information on your problem.
    Also, you are trying with freehand or Handles option?
    OP
    Hi ,
    I am trying to use 'Map to surface'  option .
    PFB the Image. Basically I want to retain a standard mesh to similar type of bracket with different sizes .e.g. L shape Brackets.
    This you could achieve even without morphing....Use the translate & delete some existing mesh.
    With Morphing you could explore Map to Geometry option with domains and handle concept or Map to surfaces with fit to target(consider only individual planar or curved faces during morphing for map to surfaces).
    Refer Morphing tutorials & user guide for more help.
