How to clean zero length beam element
Hello,
After importing the 1D beam element model into Ansys, I found some zero length beam elements which is created by the same node and that I would not like to create. I would like to know how to clean these elements in hypermesh? I know that Hypermesh has tools to clean very small length curves but these curves are attached to surface elements (Geom => edge edit / autocleanup). But in my model there are only 1D elements (only beam, column and no surface), so these tools do not work.
Thank you for your help
1 - 3 of
31
Hi,
go to check elements panel (F10)>1D and specify 'length' as 0 or some very small number and 'save failed'. Open delete panel (F2), click 'elems' to access extended entity selection, then 'retrieve' and finally 'delete entity'.
