🎉Community Raffle - Win $25
Join and Win
How to clean zero length beam element
ve3DUser: "ve3D"
Altair Community Member
Updated by ve3D
After importing the 1D beam element model into Ansys, I found some zero length beam elements which is created by the same node and that I would not like to create. I would like to know how to clean these elements in hypermesh? I know that Hypermesh has tools to clean very small length curves but these curves are attached to surface elements (Geom => edge edit / autocleanup). But in my model there are only 1D elements (only beam, column and no surface), so these tools do not work.
Thank you for your help
1 - 3 of 31
