🎉Community Raffle - Win $25
Join and Win
Combining log files
User: "kpk"
Altair Community Member
Updated by kpk
Hi,
I am solving a Transient flow problem i have stopped the problem at first Run at half the time steps and Restarted, after completion two log files are left . I am trying to view the animation of velocity results continuously in HyperView. Is it possible to combine two log files into a single file, if yes, how can it be done?
1 - 4 of 41
    User: "acupro"
    Altair Employee
    Updated by acupro
    Let try converting to h3d format using acuTrans.  Assuming the problem name is test1 and you have 2 runs to convert:
    acuTrans -pb test1 -out -to h3d -ts A -run 1 -runs 2
    That should give you the h3d file with pointers to the h3d time steps files from both runs.  Does that work for you?
    User: "kpk"
    OP
    Updated by kpk
    Hi
    Thanks for the reply
    Can you please help me how to convert ( by images/ video/Tutorial )
    User: "acupro"
    Altair Employee
    Updated by acupro
    Hi
    That is a command-line entry - not a GUI.  If on Windows, open the AcuSolve Cmd Prompt, then browse to the problem directory.
    You can issue
    acuTrans -h
    to see the complete usage of that command, and browse through the AcuTrans section of the AcuSolve Programs Reference Manual (Post-Processing Programs section).
    User: "kpk"
    OP
    Updated by kpk
    You can issue
    acuTrans -h
    Thank you very much for the reply, i will check it
