🎉Community Raffle - Win $25
Join and Win
How to input C, D, E and F points of a L-section beam under bending?
User: "Anees Sunesra"
Altair Community Member
Updated by Anees Sunesra
L section beam is a non-symmetric cross section beam so it seems a bit uneasy task to insert the 4 points, viz. C, D, E and F points of the cantilever beam under bending from the free end. Can anyone help me out here?
1 - 3 of 31
    User: "Adriano Koga_20259"
    New Altair Community Member
    Updated by Adriano Koga_20259
    Instead of using a PBEAM property, you can easily use a PBEAML property, as it already have the most common standard sections, and automatically computes stress points 1 to 8 for you, as the attached document from PBEAML help of OptiStruct.
    User: "Sohan Desai"
    Updated by Sohan Desai
    How can you locate cdef points in L-section Explain clearly
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Y and Z are the local section coordinates, as shown in the picture below.
    The stress values are computed for the local Y and Z axis going through the section Shear Center.
    Just like the image on the PBEAML documentation:
    If you define points C, D, E and F like this, you will get the same results as teh PBEAML
    Notice that PBEAML property already give you these points with no need of further definition.
    PBEAM (elements 1 to 10)
    PBEAML (elements 11 to 20)
