Why the following "executeAlgo_c : Execution failed." error shows in Altair flux during single point load simulation?
Moses Stephen
Moses Stephen New Altair Community Member
edited April 2023 in Community Q&A
Can anyone explain why the 'executeAlgo_c : Execution failed.' is coming?
Check physics and mesh does not show any error?
Answers
  • Lavanya Vadamodala_20519
    Altair Employee
    edited April 2023
    Hello Stephen,
    It is difficult to understand the issue with the error message.
    Can you share the message on the Advanced tab?
    Also, can you share the model?
    Thank you,
    Lavanya
  • Karun Avula
    Karun Avula
    Altair Employee
    edited April 2023
    Hi Stephen,
    Thank you for contacting us.
    I hope now you are able to create a support case. The error message is not having the full information. Can you please share the model by creating a support case. We will investigate the problem and let you know. By the way are you using any compressible mechanical set in the model? What is the application?
    Thanks and regards
    Karun Teja
Welcome!
Welcome!
