Can anyone explain why the 'executeAlgo_c : Execution failed.' is coming?
Check physics and mesh does not show any error?
Hello Stephen,
It is difficult to understand the issue with the error message.
Can you share the message on the Advanced tab?
Also, can you share the model?
Thank you,
Lavanya
Hi Stephen,
Thank you for contacting us.
I hope now you are able to create a support case. The error message is not having the full information. Can you please share the model by creating a support case. We will investigate the problem and let you know. By the way are you using any compressible mechanical set in the model? What is the application?
Thanks and regards
Karun Teja
