Altair RISE
Nominate Yourself Now!
Ls dyan to hm file conversion
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hii
can any one guide me for converting of  ls dyna to Hypermesh file.
I have converted file using the tool-> converts-->Ls dyana--> RADIOSS.
some of the cards is not supported for conversion. how to resolve the issue ?
1 - 6 of 61
    Altair Employee
    OP
    Hi Nitin,
     You can convert the Dyna model to RADIOSS using HyperCrash.
     Make sure you are using the latest HyperCrash 17.2 for the best translation. Start HyperCrash and pick the RADIOSS user profile.  After HyperCrash starts, go to File>>Import>>Ls Dyna, and select your Dyna model.  During import HyperCrash will convert the Ls Dyna model to RADIOSS model.
    Please try with this.
    Altair Employee
    OP
    Dear George,
    Thank you for quick response.
    Presently i am using the Hypercrash 17 version but it showing same issue.
    In 17.2 New version issue can resolved.
    Altair Employee
    OP
    Hi Nitin,
    Please try in 2017.2, and I hope it should work.
    In case if it still remains unsupported, you may have to create or update the same in RADIOSS.
    Int he installation directory we have a file which gives the complete list of cards which are supported and unsupported for Dyna to RADIOSS.
    I'm attaching the same for your reference. Please open the same in Textpad.
    Altair Employee
    OP
    Damper spring in LS dyan material card image used as SDMAT2  & DC=0.03
    For EPS foam MATL83  in Ls dyan
    In radioss which material card image use?
    Altair Employee
    OP
    Hi Nitin,
    You can model foam material with /MAT/LAW38 in RADIOSS, which is Visco-Elastic Foam Tabulated Material.
    For MAT_DAMPER_VISCOUS you can use /PROP/TYPE13 , Beam Type Spring Property Set .
    Altair Employee
    OP
    Thank you.
    conversion done on 17.2 version
