🎉Community Raffle - Win $25
Join and Win
Using the *elementtype and *elementsettypes commands
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
How could I go about using the *elementtype and *elementsettypes commands in Hypermesh, is there a listing of config and element types that I could use for the same ? For example to know what config and element type ids match the F3D3 element type ?
Thank you.
1 - 6 of 61
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    you can use hm_entityinfo to find elem type names and ids
    Altair Employee
    OP
    Hi,
    @tinh : I did try that, however I wanted to know if a list of mappings exists for element configs and element types as well ?
    User: "tinh"
    Updated by tinh
    Hi, if a list is not existing, generate it:
    set ListConfigType {}
    foreach Config {tria3 quad4 tetra4 penta6 hex8} {
         set TypeIDs [hm_entityinfo configtypeids elems $Config]
         puts '$Config:\t$TypeIDs'
         dict set ListConfigType $Config $TypeIDs
    Altair Employee
    OP
    @tinh : On running the above code, I get the following output,
     tria3:    1 2 4 17 5 6 7 27 19 22 quad4:    1 2 3 4 52 53 5 6 58 63 7 64 56 57 tetra4:    1 2 3 4 5 6 7 8 penta6:    10 18 19 1 2 3 4 5 8 9 6 7 12 13 14 15 16 hex8:    5 1 2 3 4 6 7 8 9 10 11 12 13 14 17 18 15 16 20 21 22 23 24 25 27 32 28 29 30
    However, how could I find out that which numbers from the above list correspond to what element types (such as SFM3D3, SFM3D4, S3 etc.) ?
    User: "tinh"
    Updated by tinh
    Hi,
    did you use  hm_entityinfo  ?
    ex:
    set TypeIDs [hm_entityinfo configtypeids elems quad4]
    set TypeNames [hm_entityinfo configtypes elems quad4]
    foreach TypeID $TypeIDs TypeName $TypeNames {
        puts 'Quad4 type $TypeID --> $TypeName'
    Altair Employee
    OP
    @tinh : Thank you. I wasn't aware that I could extract the name of the element type this way along with the id of the element type.
