How to apply a centrifugal load on a blade geometry
I want to apply a centrifugal load to a single blade geometry but not sure how to use RFORCE card to apply that?
In the help of RFORCE following parameters need to be specified
G - origin of rota vector
CID - coordinate system of vector
R1R2R3 - components of vector
IDRF - id of element set applied this force
How to calculate and define R1 R2 and R3? can someone explain with an example?
Hi moeen
R1, R2, R3 are rectangular components of the rotation direction vector. The vector defined will pass through point G
You can specify the direction of rotation by defining R1, R2, R3.
Have a look at this example file where the direction of rotation or Rforce is defined in the Z direction.
Thanks for the info now its clear to me but one more question. I need to define the centrifugal load of 100 rpm so i am thinking where should i insert that? under A or under RACC coz one is angular velocity and the other is angular acceleration?
Hi moeen
In RFORCE card, you have a provision to input rotational velocity or acceleration. If you have the units of Rev/sec, then you need to input under the velocity.
If you have the unit of rev/sec2 then, you need to input under acceleration.
In your case, you can input the value under angular velocity.
Hi moeen
Thanks a lot for clarification but one more clarification. What units should we use here? rev/s or rad/s???? its quite confusing for me at the moment.
In the manual it says radians below
angular velocity = →ω(radians/unittime)=2πA⋅→R
whereas in the same page it also mention that A is a Scale factor of the rotational velocity in revolutions per unit time. so here its saying revolutions.
but in one of the post the admin mentioned rev/sec. Can you please clarify this ?
https://community.altair.com/community?id=community_question&sys_id=2696047a1b2bd0908017dc61ec4bcb99
Hi moeen
You should give the input in the form of rev/sec.
The radians per second is the SI unit of angular velocity.
Here if you have the input in the form of rad/sec, then you have to convert it into rev/sec while inputting into HyperMesh.
ω = 1 rad/s, corresponds to a frequency of rotation of 60/(2π) rpm ≈ 9.55 rpm
Hi moeen
