🎉Community Raffle - Win $25
Join and Win
Optistruct is not installed currently
User: "Hector Moran"
Altair Community Member
Updated by Hector Moran
Hello.
I've recently tried to make an static analysis from HyperMesh to OptiStruct but there is an error which says "Optistruct is not installed currently". So, I installed the mechanical solver from OptiStruct but the error does not disappeared . Should I uninstall and install again HyperWorks? Or is there an other way to connect OptiStruct with HyperMesh?
I have the complete HyperWorks 2021 version.
Regards.
1 - 6 of 61
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    For installing HyperWorks package, you must use the master Installer (hw2021_win64.exe) and keep all the other installers in the same folder.
    You have probably installed them one by one, thus they got disconnected.
    Please use the master installer to get them all installed.
    OP
    I just look for hw2021.1_win64.exe in the Marketplace, but the only installer I found is hwDesktop2021.1. I don´t know the place where I can found that other installer.
    Sorry to answer late.
    OP
    Is there a possibility to make a videoconference? I really appreciate if you could guide a collogue and me, please.
    Regards.
    User: "Sokratis Kolozof"
    Updated by Sokratis Kolozof
    Can't find it either, what's the name of the file ? I can only find the desktop too
    User: "hemanth kollipara_20292"
    Updated by hemanth kollipara_20292
    Regards.
    Have you sorted out the problem cause I am facing the same problem since two days and worst of all I am unable to see hyperworks desktop application even though I installed the student edition bundle.
    User: "Rajashri_Saha"
    Altair Employee
    Updated by Rajashri_Saha
    Hi Sokratis,
    As mentioned by Adriano, you need to have the Master installer (see the image). You should have below 3 .exe files at one place and then do the installation.
    Thanks
    Rajashri
