🎉Community Raffle - Win $25
Join and Win
Rigid Body
User: "HARIKRISHNAN T S_21445"
Altair Community Member
Updated by HARIKRISHNAN T S_21445
Hi
i created contact between ( tie ) shell and solid body . but there is slightly penetration between them . Here shell elements( slave ) i mentioned as rigid body . so if i give adjust function the slave nodes will move? also the adjust function for rigid body is feasible?
thanks in advance
1 - 3 of 31
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi @HARIKRISHNAN T S
    What is the solver you are using and what type of analysis is it?
    You can de-penetrate the slave and master by moving away from each other.
    OP
    Hi @Prakash Pagadala
    Here i am using abaqus solver and it is static analysis
    > here i need to maintain the shape . my doubt is if i give adjust option ( yes ) the rigid body ( slave ) will move ?
    > also one more doubt what i the default value for that adjust option in tie contact ?
    thank you
    Altair Employee
    I am not really sure about Abaqus. I would suggest you check with Abaqus support for the same.
