Rigid Body
1 - 3 of
31
Here i am using abaqus solver and it is static analysis
> here i need to maintain the shape . my doubt is if i give adjust option ( yes ) the rigid body ( slave ) will move ?
> also one more doubt what i the default value for that adjust option in tie contact ?
thank you
I am not really sure about Abaqus. I would suggest you check with Abaqus support for the same.
Hi @HARIKRISHNAN T S
What is the solver you are using and what type of analysis is it?
You can de-penetrate the slave and master by moving away from each other.
