Error during execution of Process Template 2017.2
User: "ArunC"
Altair Community Member
Updated by ArunC
Dear ALL
During execution of Process Template, the following error is reported, do anyone encountered the same, request resolution pls
org.mozilla.javascript.WrappedException: WrappedException of encoded string too long: 193151 bytes
    while executing
"# Compiled -- no source code available
error "called a copy of a compiled script""
    (procedure "::hw::pmgr::PmgrExecutePmgrScript" line 1)
    invoked from within
"::hw::pmgr::PmgrExecutePmgrScript $strJSCmd"
    ("getadvselmethods" arm line 21)
    invoked from within
"switch [ lindex $args 0] {
  "getadvselmethods" {
  foreach {entity} $args break;
if { [string match HmEntSelCol HmMarkCol] } {
  *createentitypanel E..."
    (procedure "::hw::pmgr::pmt::task3::CollectorHandlerElementshmcol2" line 3)
    invoked from within
"::hw::pmgr::pmt::task3::CollectorHandlerElementshmcol2 getadvselmethods Elements"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [set ${nsPath}::p_callBack(default)] $args"
    (procedure "p_EvalNotifyDefaultCallback" line 3)
    invoked from within
"p_EvalNotifyDefaultCallback $nsPath getadvselmethods [ set ${nsPath}::p_text ]"
    (procedure "p_GetAdvSelectionMethods" line 17)
    invoked from within
"p_GetAdvSelectionMethods $nsPath "
    (procedure "p_EntityAdvSel" line 10)
    invoked from within
"p_EntityAdvSel .task3.canvasFrame0.canvasBoxFrame.canvasBox.mainWnd._hmcol2.coll"
    ("eval" body line 1)
    invoked from within
"eval p_EntityAdvSel $frame"
    (procedure "::hw::pmgr::pmt::task3::p_UpdateCollector" line 27)
    invoked from within
"::hw::pmgr::pmt::task3::p_UpdateCollector .task3.canvasFrame0.canvasBoxFrame.canvasBox.mainWnd._hmcol2.coll collector"
    invoked from within
    (procedure "::hwt::ReleaseCanvasButton" line 1)
    invoked from within
"::hwt::ReleaseCanvasButton 0 .task3.canvasFrame0.canvasBoxFrame.canvasBox.mainWnd._hmcol2.coll.colContainer.collectorButton"
    (command bound to event)
Thank you,
Arun
1 - 1 of 11
    User: "Michael Herve"
    Altair Employee
    Updated by Michael Herve
    Hello @Arun Theepan C ,
    were you able to get rid of this error message? It seems to be related to Java, and few months ago some Java versions were blocked by compnies due to security breaches.
    Did you have any chance to run the same process from a more recent version?
    Best Regards,
    Michael
