Hi Di,
Is this related to running a GPU simulation? Are you running locally with the user interface or remotely using command line?
You may need to initialise the GPU solver as shown in lesson 15.2 of the e-learning:
https://learn.altair.com/course/view.php?id=147
Regards
Stephen
Hi,
I was trying to apply UFRJ breakage model. The simulation was done on HPC cluster which doesn't include a GPU. I have checked the settings and the GPU option was not ticked.
Could you please let me know other possible cause to this error?
Thanks.
Hi,
Thanks.
Hi Di,
Is it possible to share the input file for us to test?
Regards
Stephen
Dear Stephen,
I would appreciate it if you could kindly provide an email for me to share the file as it is confidential.
Thank you!
hi Di, it's best to send to hwsupport@altair.com and we'll pick it up, it's best to mention it's part of discussion with the EDEM team so it gets assigned to the correct group.
Also you can create a case here and choose EDEM - https://community.altair.com/community?id=csm_get_help&sys_id=de45c412c312310015519f2974d3ae1b
Thanks! I have created the case.
Hi Di,
Regards
Stephen
