Hi,
I'd like to apply a pressure load on a fully axisymmetric pipe which I modelled with CTAXI Elements and the property PAXI.
In the picture below, you can see the crossection of the vertical pipe, on the left side the meshed region and on the white line I'd like to apply a pressure.
Error message:
'PLOAD 2 25.0 473 475 0'
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 6.
Is it not possible to use pressure loads in combination with axisymmetric elements in optistruct?
Thank you
